JD 318 riding mower
cweldon
08-05-2005 09:52:49
just back from maintenance, the two outer blades engage but don"t cut well. any adjustment that can be made? appreciate all those who know more about this than i do. thanks for any suggestions.
clifford
Timberoak
08-05-2005 17:33:11
 Re: JD 318 riding mower in reply to cweldon, 08-05-2005 09:52:49
First thing I would check is to make sure the blades were not installed up side down, flat side to the ground
dads730
08-05-2005 15:02:32
Have you checked the tension spring on the deck drive belt? Sometimes they get full of ???? and get rusty, then break. It is possible the bearings are going out on two of the spindles but I'd bet on the tension on that idler pulley and drive belt.
Bob
08-06-2005 04:19:11
 Re: JD 318 riding mower in reply to dads730, 08-05-2005 15:02:32
Besides the deck belt tension spring breaking, the idler arm can sieze up to it's pivot sleeve, so the spring can't move the arm, to keep the belt tight.
RalphinWI
08-05-2005 14:01:57
It sounds like the deck belt is loose.
