720 DIESEL QUESTION
MDM
08-04-2005 11:16:57
Can the pony be removed from a 720 and be converted to electric start and what is all involved in this process?
buickanddeere
08-06-2005 06:46:43
 Re: 720 DIESEL QUESTION in reply to MDM, 08-04-2005 11:16:57
You can but it can be more work and money that repairing the cranking engine. Most cranking engines just need some tuning and somebody running them that knows how. If the ignition system is up to spec and firing all four plugs. And the entire fuel system cleaned and properly set. Between the two and reading the operator's manual, that cures 95% of cranking engine problems. If you are going to butcher and de-value the tractor. At least save every part and piece in a sturdy and well labled packing crate. Then store in a safe dry area ands let everybody in the family know it's there. I've went to purchase tractors and nobody knew what Uncle Fred did with the fenders, pto cover, three point hitch and the cranking engine. The tractor wasn't worth bringing home when missing three grand worth of parts. The heir's of the estate were certain that I could get all those parts cheap at a salavge yard. But then said why bother because it still " runs out good" without them.
GPULLER
08-05-2005 07:58:13
I converted my pony start 720 to electric last winter. I was really simple, I had been collecting all the JD parts to do the job. To do it correctly you would need, water manifold, intake manifold, starter mtg bracket, coolant block off plate, and throttle linkage mtg bracket, foot pedal for decompression, crankcase breather. I put a 12v starter on mine. I used 2 group34 battries that are 750CCA each, which fit into the pony start battery box, my divider for the battery was rusty so I just cut it out. I put on a GM altenator and made my own wire harness, wired to the original ignition/light switch and still use the orginal starter button. Sometime I"ll find a gas hood and the correct dash, but right now it works great and I wouldn"t go back to a pony motor. Some might say it"s not correct or original but it works, it"s a clean installation and it"s mine...so I don"t care.
Soldier Tom
08-04-2005 16:58:32
I saw somewhere a man had put a 12 or 14 hp briggs and stratton engine onto the pony transmission and it worked well according to the article. They put a pipe plug in to the block where the waterline ran, added a breather into the crankcase, and routed the gasline and exhaust just as normal. The pull string was still there and everything was painted JD Green. It actually looked pretty good when it was all said and done.
Just a thought..
I have seen advertised the plate to convert to a starter, and there are several threads on this site I recall.
Let us know.
~Walk in peace~
Soldier Tom
Mike M
08-04-2005 11:39:24
Yes it can be converted,many have. It could get pretty involved if you want it to look like it never had a pony motor. If you just want it usable and not fussy about the looks people sell fabricated starter mounting plates,and it shouldn't be too hard to block off the water inlets and outlets.
