1010 hydraulic problem
JIM LONGEST
08-03-2005 14:39:20
The hydraulic oil in my 1010 keeps going down. I noticed the oil in the transmission case had turned white so I changed it and it turned white again. Also, oil ran out when I took the filler plug out. I am assuming the hydraulic oil is leaking into the transmission case. Is this possible and if so what is the fix. THANKS
Tx Jim
08-04-2005 09:36:11
 Re: 1010 hydraulic problem in reply to JIM LONGEST, 08-03-2005 14:39:20
Jim,do you park your 1010 outside? The white colored oil is usually caused from water,which in turn would make your sump over full. If I remember correctly 1010"s trans. and differential is one compartment. A good place for water to enter sump is gearshift. Tx Jim
