4020 question for Bob and others- Hydraulic
Nylon
08-03-2005 13:27:33
Bob thanks for the info on the neutral wire. It is yellow with alot of splices in it. I will take a look and try to find that switch. I bet that it is set close so that a little heating puts it just beyond contact.
Anyway the question I have is where do I find this screen for the hydraulics? I am pretty sure my brakes are fried. I am about to drain the oil and look for fistfulls of metal. I don't know where the screen is located or the sump. I have a new filter ready to go. I need to pick up oil. Any suggestion as to what hydro oil. A good quality hydro oil good enough? As long as I am asking about oil...this 68 diesel synchro...what motor oil you recommend? Northern Minnesota where it will get dang cold. Summer oil and winter oil. Do I dare try detergent and have it clean it out. It may be ok but I almost dont want to find out that varnish and such is the glue keeping her running nice. It startes very well but it does smoke a bit. I can hear the valves getting tapped a little louder than I like. I am not sure if that is old oil or sticky valves.
Also is there a way to view the brakes from a port of some type to see what the pads look like? I have a cab and roll bar which makes a brake job an unpleasant thought.
I copied a reply to another post that you made mention of the screen on below. Thanks for the help.
John
The first thing to do is drain the rear end of oil and remove the hydraulic oil strainer and clean it. If there is a problem with one or more of the brake pads, there will be brake material and probably metal in the sump and on the screen.
If this is the case, get the brakes fixed before continuing to use it, or you will risk further ($$$) damage.
If the strainer is not full of brake pad material, clean and reinstall it, and replace the oil.
Also, change the hydraulic filter. (2, if it is a powershift).
If that doesn't help, you could have a bad transmission pump, a bad main (front) pump, or a high pressure leak-to-sump at one of the SCV's, the steering unit, or the 3-point.
Tests with a flowmeter will narrow that down to the bad component.
buickanddeere
08-05-2005 16:04:14
 Re: 4020 question for Bob and others- Hydraulic in reply to Nylon, 08-03-2005 13:27:33
Mother Deere sells a manual destroker for the hydraulic pump. That removes a lot of cranking load during start-up.
Mike M
08-04-2005 05:05:49
If you really use it when real cold you may want to put in the JD low-viscosity HY-Gard trans/hyd. oil.
3010 Ken
08-04-2005 04:18:53
Morning Nylon;Like Scrib says there is only one way to get to the brakes and thats removing the finals.Also,I would go with the Hyguard oil from your J.D. dealer.Probably 10-30 motor oil would be good.If your vavles are noisy it may be a good idea to check the clearances on those while you are working on it.If the winter proves too cold for the old girl to start good,you might try a heating pad wrapped around the oil pan with the tractor sheltered from the wind.(Living in La.I don't face that challenge).If you have a problem removing the plug to get to the filter screen,call on Mr. Woodbutcher on this site,he is an expert on this.Good Luck. Kenny
woodbutcher
08-04-2005 04:37:45
 Re: 4020 question for Bob and others- Hydraulic in reply to 3010 Ken, 08-04-2005 04:18:53
Well, thank you, Ken. I feel like I've made all the mistakes that could have been made trying to get that screen out. Then I found it totally clean. But now I don't have to wonder. After destroying the square shoulders on the plug, the replacement plug at the John Deere house was the 1/2" square female type for older models. I think this is the better design.
Butch
Scrib
08-03-2005 20:50:06
John,
Brakes: there is no port hole for the brakes unfortunately. To change pads you have to remove final drive assemblies. Not FUN!
The screen is located behind the plug which is located below and behind the transmission oil filter.
My suggestion is to dump the oil out and change the transmission filter and cut the filter apart and inspect for paint (yellow). If you find yellow paint - don't be alarmed.
No need to flush.
Just any "hydraulic transmission" fluid.
I'm in central Alberta Canada and I use 1540 for summer and 0-30 synthetic if it's really cold - like -25 or worse.
Hope this helps.
Nylon
08-03-2005 22:03:21
 Re: 4020 question for Bob and others- Hydraulic in reply to Scrib, 08-03-2005 20:50:06
Scrib.
Thanks for the info. That winter oil of 0-30 must be something :] That must be 10 - 30? I can't imagine 5 not flying right through the engine. This 4020 is new to me so I am gonna pull the screen and see what I have going on. Since it smokes a bit I have to believe it is fairly loose and would have to go with a heavier oil. I am really hoping that I can get this thing to run / start at -5 to - 10. There are lotta sunny calm days that warm up to - 5 after a front that dumps enough snow that I have to blow. I plow most of it but once banks get high and windblown I have to blow em out. I can usually hold out for a warm up to blow but not always. Been doin it with a 460 Farmall till now. Great machine but the cab with a heater has some appeal ;].
There is a circulating heater on it now but the supply wires are fried and I think it is 500 watts. I think I will hook up a 1500 watt. No sense fooling around.
Any cold weather advice from Canukistan is always appreciated. I know you spend plenty more days in the cold than I do. How do hydraulics react to that cold? JD pump do ok? 460 is pretty creaky till its pumped some oil.
Thanks,
John
R. John Johnson
08-04-2005 06:30:40
 Re: 4020 question for Bob and others- Hydraulic in reply to Nylon, 08-03-2005 22:03:21
Nylon
Here is some cold weather starting advise from the frozen tundra of Manitoba. I use 10W 30 oil in the winter, but I know of a lot of people up here who use 15W 40 year around. Any tank type coolant heater needs to be 1500W. If it is an in block element replacing a frost plug, get a 1000W model. Don't be cheap and try to use a timer to limit how long you run the heaters. Saving a few pennies is a poor trade off against cold start wear and tear on your engine. Or not being able to start it. Get it out of the wind. In a shed is great, but if not get two batts of pink insulation and place them on each side of the engine. Lean some boards against the batts to hold them in place. Our 4010 came from the factory with a engine oil heater in the oil pan. Having the engine oil at a consistancy less than maple syrup really helps. On New Gen tractors turn the steering wheel while you crank. The main hydraulic pump is trying to build up to full system pressure which puts extra load on the starter. Turning the steering wheel gives the oil a path back to tank. You are still pumping oil, but that is easier than pumping oil to build pressure. Good batteries and large(read low electrical resistance) battery cables are a must. Txgrn has posted info on this in the past. If your batteries are weak you can put a trickle charger on them overnight. I do not like ether. A lot of large farm here have outdoor wood furnaces heating their homes. These furnaces have enough capacity that they can also heat a shop at virtually no extra cost. Nothing beats trying to start your tractor in a 50 degree shop when its -25 outside. Wish I had one. One last thought. When you do get your tractor to start, let it warn up before you use it. When I start my feeding tractor in bitter cold, I start it first and then go in the house and have breakfast. When I start to use it, I go slow and gentle at first until everything is loosened up.
These are my thoughts on the matter, hope it helps.
John
