If they're like my 2010 brakes, they consist of a pack of 3 disks with facings and 2 cast iron pieces with balls in bevelled grooves between them such that when you push the pedal, the balls tend to wedge themselves tighter between the plates, theoretically giving a degree of "power brake" action to the mechanism. I did my brakes almost 10 years ago because they were rusted and worn out, but I can't say they're really good even now. I seem to recall the friction disks (look like small clutch disks) were $50 apiece and I ended up salvaging 2 of the old ones so I was in it $200 for parts just for the disks. With all new disks and new cast iron pieces, and today's prices, I can see $750 easily. My 2010's got a heavy backhoe/loader frame built around it, and going down any kind of hill at all, I still have to push with all my strength on the brake pedals to stop it. At least it does stop, which is better than it used to be, but it makes me nervous when I'm using the loader to dump over the side of a steep hill! In that situation, I can't use my usual "emergency brake" expedient of dropping the loader bucket. Frankly, the brake disks just look way too small for the size of the machine, and the mechanism doesn't provide any way to dissipate heat from inside the disk pack. The outer disks work against the brake cover on one end and the final drive housing on the other, but that still leaves 5 inside surfaces with no way to get the heat out.
