48 A flywheel
giovengo
08-03-2005 06:30:07
i am fixing a cracked flywheel on a late a. i found a good flywheel and replaced it. the number is a3264r. this is actually a 60 flywheel. is this correct for an a? also my endplay is .045, do i measure with the clutch engaged or disengaged. last does anyone know the torque value for the clamp bolts? thank you for your advise.
Mike M
08-03-2005 09:55:24
 Re: 48 A flywheel in reply to giovengo, 08-03-2005 06:30:07
That 60 flywheel will work on an A,but it may not have the timing mark on the web as 60's were marked on the outside rim. The clutch placement does not matter for setting end play,you should block the crank all the way to the left before you put on the new flywheel it will help you.Make sure the pin for the oil slinger goes into the slot. I don't think there was a published torque on those bolts,use the factory tire wrench and give it your all -- no cheater pipes.
