JD 1944 A rear end gasket
wilson
08-02-2005 16:41:20
Fixing to put a gasket in 44 A i am restoring I need a new gasket between transmission and rear axel housing. The question is how far can I move the axel housing back without getting pto out of splines?? I can fix gasket in with one half inch but one inch would be easier. I plan on using 2 longer bolts at top right and left holes cutting small place in gasket to slide in place. Thanks for your help P.S. I will take pto and pump apart as i must take idler gear out and add live jd pump on mag drive.
Mike M
08-03-2005 05:47:43
 Re: JD 1944 A rear end gasket in reply to wilson, 08-02-2005 16:41:20
I would not CUT THAT GASKET as that is asking for more leaks. Just support the front half real good and roll the back end away so you can get in there and clean everything up. You should not have much trouble from that pto just rotate it as you go back together to make sure it lines up.Sometimes you need to put it in gear so the front half doesn't turn.
