1939 B with a six speed transmission
Sambo
08-02-2005 16:18:39
I have a 1939 John Deere B with a six speed transmission it has the high/low shift lever and it has the gear pattern 1/3 2/4 5/6 and reverse this all looks origonal. Can someone help me out? I"ve been reading they only came with 4 speeds so could this be a factory option or some kind of rare thing and is it worth more with this; it sort of has me stumped.
Sambo
08-04-2005 17:32:41
 Re: 1939 B with a six speed transmission in reply to Sambo, 08-02-2005 16:18:39
Is it possible for them to have bolted a transmission on there without putting a different block on it. Can someone give me some casting numbers to see if they are 1939 parts and what are some major differences in a 39 and a post 41b looking at pictures I have the later type of brakes and my flywheel is different from alot of the pictures of 39 Bs
Deere John 2004
08-05-2005 07:41:58
 Re: 1939 B with a six speed transmission in reply to Sambo, 08-04-2005 17:32:41
Sambo;
The main case, containing the transmission & the crankshaft is one piece, so they couldn't just bolt a different transmission to the engine. By the way, its also where the serial # plate is attached, so if they changed that case, the serial # would be changed too. I think they could have changed all the internal parts of the transmission to change it. The gears for 5th & 6th gears are external, by the flywheel. I'm sure all the parts will fit, I just don't know about the shifting fork rod, I don't know if it used the 2-4 gear rod, or if there was a separate shaft for that. Bendix made a kit to make a 4 speed a 6 speed, but that used a separate shifting level on the flywheel side of the tractor.
LOL PJCW
PeterE
08-03-2005 11:00:40
I didn't know the B had a six-speed that used a high-low shift lever. My 1951 has six gears in the shift pattern. When was that change made?
CLW
08-03-2005 20:56:19
 Re: 1939 B with a six speed transmission in reply to PeterE, 08-03-2005 11:00:40
The B had high/low until the late styled B came out in 47.
CLW
dickD
08-02-2005 18:17:19
Sambo Have you run the serial number to make sure it is a 39?
Sambo
08-04-2005 16:36:36
 Re: 1939 B with a six speed transmission in reply to dickD, 08-02-2005 18:17:19
The serial number checks up its 72XXX and is located under the mag
old
08-02-2005 18:08:45
My guess would be you have a front from a 39 and the rear from say a 41 up
Deere John 2004
08-02-2005 17:21:09
Although the 6-speed transmission was not offered on the B until 1941, I don't think the transmission case itself was changed. So, I guess someone could have used parts from a post-'41 B to convert yours to a 6-speed. Just a thought.
Sambo
08-04-2005 17:22:37
 Re: 1939 B with a six speed transmission in reply to Deere John 2004, 08-02-2005 17:21:09
Alot of the parts from later B's aren't interchangable with 39's and i don't think deere would've made it so a later 6 speed transmission could fit into the same space as a earlier 4 speed and just bolt right up
Ralph, Ohio
08-02-2005 16:55:51
How do you know it"s a 39? I never heard of one with 6 speeds.
