Charging Battery on Two battery system? JD
Leland Jamesl
08-02-2005 03:42:16
I want to the Jump off and also charge the (2)battries on my 1120 JD without damageing them or electrical system. They are hooked up (+ to +) and (- to-). Can I Just jump them off from another Batt(truck) like any other, or do I need to( unhook) and do them seperate? If you jump them off without disconnecting them do I charge them like that? Please help
Leland
Mark57_420
08-02-2005 10:29:10
 Re: Charging Battery on Two battery system? JD in reply to Leland Jamesl, 08-02-2005 03:42:16
Make sure you"ve got a good, heavy set of cables (prefferably the shortest you can get by with) before you try to start her with jumper cables. I melted a set quicker than you could realize what was happening years ago trying to jump start a 12V 4020D.
John T
08-02-2005 05:46:25
Leland, if they are + to + and - to - as you say????? they are in paralell. Therefore, you can jump them with no need for disconnecting and likewise, charge them as a single unit again no disconnections, otherwise you wouldnt be charging the one thats removed. Its less important for a lower current rate when charging them in parallel, but when I say "jump" them with an external battery, I am assuming they are connected with large batery cables capable of handling large and approximate equal currents for BOTH baterys.
John T
LELAND JAMES
08-02-2005 07:05:44
 Re: Charging Battery on Two battery system? JD in reply to John T, 08-02-2005 05:46:25
I quickly looked at it but will check closer when I get home . I guess by the??? you think they may not be hooked up +-+ and -to-.
Would they still be 12v system hooked up anyother way? As you can see I don't know much about this and I thank you for your help.
Leland
John T
08-02-2005 08:23:17
 Re: Charging Battery on Two battery system? JD in reply to LELAND JAMES, 08-02-2005 07:05:44
If its two 12 volt batterys in paralell, its still 12 volts and all I said above remains true. If two twelve volt batterys were in series + - + - , however, that would be a 24 volt system, but thats mostly in larger diesel tractors. The only reason I questioned was Im unfamiliar with most tractors after the 2 cylinder series and unsure what yours has.
John T
tyho
08-08-2005 19:04:35
 Re: Charging Battery on Two battery system? JD in reply to John T, 08-02-2005 08:23:17
+ to+ and -to- this will increase the amps available, +to- will increase the volts. Most 2 cycl came with two 6 volts + to - so they came out to 12 volts. You can put as many batteries as you want +to+ and - to- IE one diesel pick up jumping another this would be 4 battires. This will increase the amps available. As far as charging them leave them togather. If you charge one and then the other they will not have the same charge. As soon as you hook them togather they will even out anyways. If you do not have a heavy enough cable between them you will have problems.
