4 questions about John Deere 70 powersteering conv
Leeks Hollow
08-01-2005 21:31:26
To All:
I am in the process of rebuilding a John Deere 70 gas. While I have it all torn apart I wanted to update from the manual steering to powersteering. I was told that I could flip the pedestal and pump from a 70-720-730 into my 70. I was encouraged to find one out of a 720 or 730 as it had improved design. I have located a 730 junker that I can get parts from. Enough backround... here are my 4 questions.
1) This junker was in a fire. Would this do any permanent damage to the parts I need?
2)What parts do I need to scrounge off the 730 to make the conversion work?
3) What will I need to modify to mate the 730 parts to the 70?
4) What parts should I just rebuild / replace before installing?
Thanks for all the help,
Garrett
Larry in WNY
08-03-2005 08:50:57
 Re: 4 questions about John Deere 70 powersteering in reply to Leeks Hollow, 08-01-2005 21:31:26
Garrett,
Check the radiator top tank too. On my 60, the manual steering tractor had a taller radiator top tank and the power steering version had a different design to allow running the lines to the P/S pump from the pedastal.
Larry
Blksmok
08-02-2005 06:29:36
Leeks....the front end of the conversion (pedastal, pump,fan) is straight forward, but where the fan shaft pinion gear meets the drive gear in the governor...that's where the parts are different. You'll need to study the parts manual of a 70 gas versus a 720 gas to see what's needed for a conversion, or find someone that has done it and figured out the parts numbers combination that works.
buickanddeere
08-02-2005 05:38:48
720 pedistal yes, 720 shaft no. JD Parts manual yes.
