720 diesel clutch problem
Dustin
08-01-2005 21:22:16
I recently purchased a 720 diesel and it has some clutch problems. I have removed the clutch disc and the gear/disc that fits on the splines on the end of the crank shaft. I can see the bearing that goes around the shaft is out because the rollers fell out. what i need to know is what you have to do to get the pully off the crank shaft. I was told that you have to remove the fork that engages it but how do you do that. thanks Dustin
Mike M
08-02-2005 06:00:38
 Re: 720 diesel clutch problem in reply to Dustin, 08-01-2005 21:22:16
On those diesels you should see a row of bolts all around the plate behind the pulley. Remove all of those and work the whole thing pulley and plate off the dowel pins,have the pin out of the linkage so it can swing as you pull assy. off.
Tx Jim
08-02-2005 03:43:46
Dustin,disconnect the clutch control rod ,remove 4 bolts in rectangular part just to frt. of clutch pulley,pull rectantular part towards front of tractor. Remove pulley. Tx Jim
