All the parts and diagrams are on Mother Deere's web site. Unless your husband has a calibrated flow and pressure test bench along with the proper tools and experience. Injector service is a real good place to get into trouble, get hurt or ruin an engine. (ROOSA-MASTER) Cart KEY PART NO. PART NAME QTY TRACTOR SERIAL NO. REMARKS 1 ..... .. HOSE 1 36 MM (1.40") (MAKE FROM R68281) 2 T29540 FITTING 1 - XXXXX (SUB R79604) 3 T29539 WASHER 1 - XXXXX (SUB R79605) 4 AT27622 CAP 1 - XXXXX 5 R79604 TUBE NUT 1 XXXXX - 6 R79605 WASHER 1 XXXXX - 7 R79606 TEE FITTING 1 XXXXX - 8 AR85618 CAP 1 XXXXX - (USE WITH AR89564) (SUB R79604, R79605 AND R79606) 9 R51936 SEALING WASHER 1 XXXXX - 10 R51937 TUBE NUT 1 XXXXX - Cart KEY PART NO. PART NAME QTY TRACTOR SERIAL NO. REMARKS 11 R66090 TUBE 1 XXXXX - (SUB RE68748) 12 R34760 CLAMP 1 13 R34761 SPACER 1 14 T24472 CAP 1 15 R48000 SEAL 1 16 R34764 WASHER 1 R60746 WASHER 1 XXXXX - (USE WITH AR73673 OR AR88239) 17 AR88239 INJECTION NOZZLE 1 (SUB FOR AR56290 OR AR73673) (SUB AR89564) 18 R67779 CLAMP 1 (SUB FOR T26870) 19 T31174 CAP 1 (USE FOR SERVICING FUEL INJECTION NOZZLE) (NLA) (REPLACEMENT) FUEL INJECTION NOZZLE - CONTINUED (REPLACEMENT) Cart KEY PART NO. PART NAME QTY ENGINE SERIAL NO. REMARKS 1 R51936 SEALING WASHER 1 2 R51937 TUBE NUT 1 3 R66090 TUBE 1 (SUB RE68748) ..... .. HOSE 1 (MAKE FROM R68281) 4 T29539 WASHER 1 (SUB R79605) 5 T29540 FITTING 1 (SUB R79604) 6 AR85618 CAP 1 (SUB R79604, R79605 AND R79606) 7 R47733 LOCK NUT 1 8 R69443 SCREW 1 (NLA) 9 R62984 SCREW 1 Cart KEY PART NO. PART NAME QTY ENGINE SERIAL NO. REMARKS 10 R46675 NUT 1 (NLA) 11 R69442 SPRING 1 12 R62982 GUIDE 1 13 R67779 CLAMP 1 14 R34764 WASHER 1 15 R48000 SEAL 1 16 T24472 CAP 1 17 AR89564 INJECTION NOZZLE 1 18 T31174 CAP 1 (NLA) 19 R34760 CLAMP 1 Cart KEY PART NO. PART NAME QTY ENGINE SERIAL NO. REMARKS 20 R60745 SPACER 1 21 R62981 WASHER 1 (ENGINE SERIAL NO. 180579- ) Cart KEY PART NO. PART NAME QTY ENGINE SERIAL NO. REMARKS 1 T29539 WASHER 1 (SUB R79605) 2 T29540 FITTING 1 (SUB R79604) 3 AT27622 CAP 1 4 R47733 LOCK NUT 1 5 R47732 SCREW 1 6 R47734 SCREW 1 7 R46675 NUT 1 (NLA) 8 R47731 SPRING 1 9 R39886 GUIDE 1 10 R67779 CLAMP 1 (SUB FOR T26870) Cart KEY PART NO. PART NAME QTY ENGINE SERIAL NO. REMARKS 11 R34764 WASHER 1 R60746 WASHER 1 (USE WITH AR73673 OR AR88239) T32252 WASHER 1 - 211699 12 R48000 SEAL 1 (SUB FOR R34767) 13 T24472 CAP 1 14 T31174 CAP 1 (NLA) 15 AR49877 INJECTION NOZZLE 1 - 211699 (ROOSA-MASTER NO. 18742) AR88239 INJECTION NOZZLE 1 211700 - (ROOSA-MASTER NO. 19762) (SUB FOR AR56290 OR AR73673) (SUB AR89564) 16 R34760 CLAMP 1 17 R34761 SPACER 1 Cart KEY PART NO. PART NAME QTY ENGINE SERIAL NO. REMARKS 24H1685 WASHER 1 - 211699 11/32" X 47/64" X 0.083"
