Hydraulic oil in engine oil on JD 1020
Tommy Tompkins
08-01-2005 21:14:24
I know that this sounds impossable.
But how is the hydraulic oil getting into the engine oil ?
The hydraulic oil keeps going down and the engine oil keeps gong up.
This is on a JD 1020 with a 48 loader.
Any ideas ?
BigTomHB
08-04-2005 14:15:24
 Re: Hydraulic oil in engine oil on JD 1020 in reply to Tommy Tompkins, 08-01-2005 21:14:24
I experienced the same thing with my "66 1020... three times over. The power steering unit located on the front has a seal connecting the drive with the tractor cam ( I believe) .... anyway the seal broke free and then the higher pressure hydraulic fluid flows into the engine oil. I can replace the radiator with my eye closed now. It finally held with a bit of Locktite.
Pining the edge of the seal cavity might be helpful too.
John36bn
08-02-2005 03:36:07
Could be my imagination but I remember hearing on this site that some of the early 1020`s had timing gear driven hydraulic pump mounted to the front cover. The seal between lets go and adds hydraulic oil to the engine oil. maybe a search of this sites archives would be better then my memory.
