4020 starter button to starter motor.
Nylon
08-01-2005 19:39:25
Hi,
My 4020 68 diesle with 12 volt just decided to not restart after getting warm. I have juice to one side of the button. I jumpped from the starter button to the solenoid and she fires no problem. The relay seems fine too.
The real question requires some visualiztion. The wire bundle leading to the starter from under the hood above has a single wire pulled out of it and is spliced. It runs back behind the pannel and under the floor. This wire joins up with another wire in a woven sheath (same type of sheath as other wire bundles)has two wires in it. The other wire coming back leads to the top of the relay. I am guessing that this wire pair had been added to fix a stater button problem.
Is there typically a single wire bundle leading to 4020 starter. Or is there another 2 wire sheathed bundle that also comes off the starter and leads to the panel?
I want to cut out the old multi splice and feed a new wire through.
Note to Tractor wire splicers. Always use solder with heat shrink to join wires. Clean...solid..reliable.
Bob
08-01-2005 21:33:44
 Re: 4020 starter button to starter motor. in reply to Nylon, 08-01-2005 19:39:25
The pair of wires runs to the transmission neutral start switch.
The original color will be yellow.
