Charles, Im first unsure if you have a 2 or 3 brush generator or a 3 wire (BAT ARM FLD) voltage regulator or a 2 wire (BAT GEN) cut out relay????? ?? Regardless, heres a few beginning things to look at of she charges but its weak: 1) Its important the belt be good and tight and not glazed and the generator and cut out relay or voltage regulator are well grounded. 2) If its a 3 brush generator, they put out max current if the third adjustable brush is rotated over close to the one on its same side. 3) If its a 2 wire cut out relay and a dual purpose light switch type field current regulator, the switch could be bad or open or not well grounded. To troubleshoot that (cut out relay and light switch filed controller), use a wire and ground out the Field post (smaller of the 2) on the generator with it running at fast RPM, and if she then charges more, your light switch or wiring to it from the generator may be bad. The dual purpose (lights and field control) light switch gives the generators field a dead ground when lights are on for HIGH charge but grounds it through a resistor (on the light switch) for LOW charge when lights are off. If she shows NO charge even with the field grounded at fast RPM, next leave that and run a jump wire around the cut out relay to hook its BAT and GEN together momentarily as its running and see if she charges then. If so, the cut out relay may be bad or not well grounded. When the tractor is turned off, that relay has to open so the batetry dont discharge through the generator. 4) If you have a 3 or 4 wire voltage regulator, with the tractor running, again ground the Field post on the generator and see if she charges better??? If not, leave it grounded and momentarily jump together the VR's BAT and GEN (or ARM) terminals and at fast RPM see if she charges more????? ?? The tests above determine if you have a bad generator ORRRRR RRR a problem in the voltage regulator or cut out realy or its wiring. Loose or corroded conenctions or bad grounds to the gen or VR or a loose belt or a mis adjusted 3 brush generator may be your problem. Be sure the battery has electrolyte above all thw plates and none are gray or milky and a battery shop can load test it for you. There couild be a trickle discharge running the battery down, try disconnectign it some time and see if she stays charged that way. If so, there a short or another cause of discharge and maybe not the gen or VR????? let me know Post back or e mail [email protected] with any more questions and if I see waht you have I will then advise further. Good Luck n God Bless Ya Charles John T
