JD 3140 hydraulics
matt 6910
08-01-2005 11:03:47
Hello I hope some one can help me here we have a 3140 european build and had an hydraulic problem it seemed to me that the transmission oil pressure was leaking and the ushual pto rotating, no hydraulics etc unless you rev up. I have had this before and it was the filter bypass valve gone out i have replaced the filter, screen and chcked the by pass valve I have also checked the transmission pressure reg valve in the top cover when i re built it it worked fine for a while then it went that it would work fine at low revs but as you increased rpm you can hear the pressure reg valve in the top cover blow off and you loose hydraulics. next i checked the oil screen in the hydraulic pump thinking that it could retrict the oil from the top cover hence the top cover transmission reg valve worked as a pressure release vale and dumped the oil. but it was clean so why is the vave mking a noise when you rev up and loose hydraulics the only other thing is the oil seems like someone has filled it with engine oil could this cause it any help is much appreciated
