unstyled radiator tank
Jim Benson
08-01-2005 06:50:37
I have reassembled my 36 A and find that there is a hairline crack in the lower radiator tank. What is the most cost effective way to plug such a leak? Will stop leak, pepper, etc work in nonpressure systems? I thought the pressure is what makes those things work. (I think a lot of things that are wrong.) I also thought of filling the lower tank with gas tank sealer. Would that work? Thanks for any help.
Jim Benson
08-05-2005 05:52:22
 Re: unstyled radiator tank in reply to Jim Benson, 08-01-2005 06:50:37
Thanks for all the input . When I get this thing apart I'll get a better evaluation. This is a great discussion list.
Lynard
08-04-2005 17:19:39
Jim Several years ago a friend of mine welded the bottom tank of a styled A. It had a large crack across the bottom of it and had to make several passes to fix it. I asked if he had to heat it and such and he said it was soft cast and you could weld it without the heat. He could weld anything but a broken heart or wore out a$$hole. Lynn
Mike M
08-02-2005 11:09:22
I'd place an ad over in the classifieds and see how much you can get a good used one for ? This way it will hold up without question. Should be some around. I had no trouble finding a good one for my B.
Jason Z in MO
08-02-2005 11:39:17
 Re: unstyled radiator tank in reply to Mike M, 08-02-2005 11:09:22
Mike's advice is the best and I might be wrong but I thought the unstyled radiator tanks are hard to find in decent shape. I checked the parts book and the part numbers are different from the unstyled to the styled.
If they are obtainable that is the safe bet.
Mike M
08-03-2005 06:00:36
 Re: unstyled radiator tank in reply to Jason Z in MO, 08-02-2005 11:39:17
They could be hard to find ,you just have to try. When I did my unstyled B I was very surprised at the amount of parts around for them,even many new and NOS parts. Many more than I could afford to buy. They did build a lot of those A and B's
Jason Z in MO
08-02-2005 07:38:14
Jim,
I would think you should be able to grind a groove the length of the crack and braze it shut or use JB Weld.
