Sounds like the tractor is not getting the amount of LOAD fuel it needs and/or it is not getting enough air. You say you "have had the carburetor rebuilt;" Can we assume that a really dependable job was done there? If you don't mind, tell me who did the rebuild! An absolute must here is that you have clean fuel, a functional fuel screen in your fuel filter, and that if you did run contaminated fuel into the carb, you hAve dropped the bowl and did a full flush of the valve system. BeyonD this, - - - TROUBLESHOOTING: 1. Drop the oil bowl from the air cleaner -- you will need to place an old towell under the bowl to catch dripping oil. If the engine now runs okay, your air stack is partially/near totally plugged. 2. Run the LOAD & IDLE Path Test -- This test is conducted to double-check openness of your carburetor's IDLE & LOAD pathways by manipulating the IDLE & LOAD needles. Here is how it goes: (a) CAUTION: This test involves radical adjustment of both the LOAD & IDLE needles. Before starting the engine, observe the position of each needle lever, and count the number of turns OUT that each of the two needles is at so that you can put them back where they were before this test is run. (b) With the tractor running at least at half-full engine speed, turn the LOAD needle all the way in. The engine will continue to run if the IDLE SYSTEM is open, and if it stops running, -- the idle system IS NOT open! Assuming this test is a pass, reset the LOAD needle where is was and go on to the test below. (c) With the engine running at least at half-full engine speed, turn the IDLE needle all the way in. The engine will continue to run provided the LOAD FUEL system is open, however, in this mode, engine operation will be a throttling pattern. As engine speed drops, the governor will open the throttle to draw LOAD FUEL because the idle path is closed. This pattern, however, indicates the LOAD FUEL channel is open & working as it should. If the engine stops running, the LOAD FUEL channel is blocked. 3. The next concern I would have is a blockage in the Bowl Vent System -- this system helps to regulate surface air proessure on the fuel in the bowl. If too low (a vacuum), then fuel traveling up the LOAD Fuel Nozzle will not be at the metered rate, thus less fuel at the venturi for carburetion into an air-fuel mixture. The result is that the air-fuel mix is too lean and the engine will be sluggish, run irregular and have a hard time accelerating or taking on a sudden load. The Bowl Vent Air (in) port is seen from the intake end of the carb body, at roughly 3:00 o'clock, and is the one partially recessed into the wall of the carb body. This path MUST be open back to the carb vent. Now, looking from the ground up at the carb (without the bowl in place) you would see the Bowl Vent Cavity as a recessed hole in the carb body -- into which is placed a brass baffle. I rather imagine you see a clean, open baffle. The catch here is that beneath the first baffle sits yet a second one, visible only once the top one is removed. It is this second one that is usually surrounded by solid caked rust. Both must be taken out and then the passageways drilled to ensure adequate air flow into the bowl. e-mail me -- then I can send you some recent pix of a Carburetor from an "H" John Deere with very similar features -- showing all the detail I hve described here. 4. The final culprit I would have to look at is the fuel nozzle. During rebuild, that nozzle needed to have come out, been cleaned, the cavity it sits in cleaned, and then put back. In the event you need to remove the fuel nozzle, the bowl must be removed, and then we have: a. Removal of the fuel nozzle is not that hard. What tends to make it difficult is the build up of rust not only around the nozzle, but also under it in the path it must take to come out. Perhaps you can either bead-blast or scrape some to remove the rust that is in the path of the nozzle as it is withdraw. DO NOT attempt to push it out from within the carb throat -- could render the precious nozzle useless. b. The neatest way to extract the fuel nozzle is to go into the bottom of the nozzle with a tap, one that will just go into the hole. Run the tap down in there just enough to get a bolt into the nozzle far enough to where it won't pull away. Then take a bolt, run a nut up on it, and then a couple washers - washers with larger diameter than the carb stem diameter -- screw the bolt up into the nozzle threads you just made. Then run the nut down onto the washers to take up the slack. Now with a wrench in one hand and your finger on the tip of he nozzle, begin to tighten down on the nut. You should begin to feel the nozzle withdraw from the carb's venturi with your finger. Now if you are cranking the nut down but the nozzle isn't moving STOP. You are "pulling out" of the threaded zone in the nozzle. I like to run the tap into the nozzle by a half inch to preclude this concern. And to improve your chances for success, allow some PB Blaster or Kroil to penetrate the nozzle region for several hours up to a whole day before the withdrawal procedure.
