4230 Air conditoning System
William Tusa
07-31-2005 21:29:24
Our 4230's air conditoning compressor has the mounting bolts at the rear of the compressor broke loose from the compressor so assume it will have to be replaced?? It hasn't worked for several years so I assume the whole system will have to be replaced with new parts. Can I simple take all of the lines, compressor, receiver-dryer and other parts off myself install the new lines, compressor and leave these sealed and then take the tractor to my John Deere dealer to
evacuate and recharge and install the receiver dryer or will this not work. Please reply only if
you have had extensive air conditioning education. Thank You
Bob
07-31-2005 22:01:55
 Re: 4230 Air conditoning System in reply to William Tusa, 07-31-2005 21:29:24
Are the actual bolts broken off, or is the compressor's rear casting broken?
Is the compressor stuck or leaking?
Why are you replacing the lines... pro-actively putting on new lines that are SUPPOSED to be more R-134 tight, or is there damage to the lines?
If you are replacing the lines, check on the "conversion kit" price from Deere, as it's typically less than buying the hoses individually.
When converting to R-134, different AC oil must be used, Polyol Ester or PAG.
New R-134 systems commonly use PAG oil, while Polyol Ester oil is more compatable with small amounts of remaining R-12 system mineral oil.
However, John Deere has the one-oil-fits-all approach, and uses the (less compatible with the old oil) PAG oil in their replacement compressors, both for systems that originally had R-134 AND for R-12 conversion applications.
Therefore, a THOROUGH system flush is VERY IMPORTANT, when going that route, to eliminate ALL TRACES of mineral oil. (When non-compatible oils mix, you get an AC system filled with chocolate pudding, and that does'nt cool well!)
So, if you going the official Deere route, there is NO SENSE to install the new compressor, lines, and dryer BEFORE the condensor, evaporator, and remaining steel lines are flushed.
Replace the expansion valve.
Deere has a "thermal fuse replacement kit" to eliminate the compressor's superheat switch and the thermal fuse, and bring the compressor protection system up to the "50" series style.
This consists of a replacement flexible liquid line that connects to the expansion valve, 2 pressure switches, and a wiring harness. It's something to consider, while you're in there.
txgrn
08-01-2005 05:08:59
 Re: 4230 Air conditoning System in reply to Bob, 07-31-2005 22:01:55
The 4230 I just bought had a new 134 compressor (stamped on the compressor) installation with new lines and all. Don't know if the guy did it or the JD house, but it is professional all the way and boy does she cool. Very nice.
So if you aren't already 134 maybe now is the time to do it.
Mark
