3020 Radiator Installation Question
kdagenais
07-31-2005 19:17:29
Hello,
I am working on a 3020 serial # 106913 and was wondering the orientation of the spring & spacer that holds the radiator in place. I am guessing the spacer is suppose to be underneath the radiator to hold it up higher. The reason for the question is cause the water neck doesn't protrude out the hood far enough to get the cap on correctly. Also if someone could gice me a measurement for the spacer I would appreciate it.
Thanks In Advance,
kdagenais
08-01-2005 03:21:48
 Re: 3020 Radiator Installation Question in reply to kdagenais, 07-31-2005 19:17:29
I see what is wrong now. I am missing item 6 on the diagram. That is why we can't get the radiator cap on. Thank You for your help. Knew somehting was missing just wasn't sure what it was.
gwece
08-01-2005 06:23:32
 Re: 3020 Radiator Installation Question in reply to kdagenais, 08-01-2005 03:21:48
I think that is the filler neck on the radiator. There are actually 2 parts pages depending on the s/n of the tractor. Take a look at the other one and see if it helps. You may be missing #19.
Bob
07-31-2005 20:23:38
Here's a link to the bolt, washer, spring and spacer:
Mike Aylward
07-31-2005 20:16:27
There is a rubber strip that goes under the radiator mount on each side and the spacer and spring go on top of this mount. This is why your radiator is too high. Hope this helps. Mike
