Injection Pump timing for a John Deere 2010
Robin Simmers
07-31-2005 18:00:53
I am needing proceedures or information on where to get instructions on how to time the injection pump for a john deere 2010.
msb
07-31-2005 18:34:23
 Re: Injection Pump timing for a John Deere 2010 in reply to Robin Simmers, 07-31-2005 18:00:53
Has the pump been removed or do you simply want to set the pump timing?
If the pump has been removed then be sure to install the pump drive tang with the drilled index mark on the botton of the shaft in line with the drilled index mark in the oil pump drive slot.Next install the two cap screws in the pump base.With the pump turned as far it will go counter clockwise,lightly snug down the cap screws.Remove the timing window on the pump and the flywheel.Then slowly turn the flywheel in its normal direction until the D/C on the flywheel lines up with the mark on the bell housing.If you go past the mark on the flywheel,turn it back at least a quarter turn to remove any backlash.Once the flywheel is correctly positioned then loosen the cap screws in the pump base and slowly turn the pump in a clockwise (as viewed from the top)direction until the timing marks in the timing window line up.Tighten the cap screws. If the pump has been rebuilt,rarely does the linkage line up as before .So you will probably have to reset the throttle linkage to attain the correct engine speeds.
Robin Simmers
08-02-2005 20:46:50
 Re: Injection Pump timing for a John Deere 2010 in reply to msb, 07-31-2005 18:34:23
What my husband needed to know is the oil pump has been removed and the engine has turned so we need to start over on the timing where the oil pump and injection pump all line up together to time the injector properly.
Joe Stewart
08-03-2005 05:04:36
 Re: Injection Pump timing for a John Deere 2010 in reply to Robin Simmers, 08-02-2005 20:46:50
You need to align the "D/C" mark on the flywheel with the pointer in the little round window of the bellhousing first. Then install your oil pump per the JD factory service manual (If you don't have one, you should probably get one for this procedure and others. I'll fax you the pages if necessary). Then install your injection pump paying particular attention not only to the timing mark in the rectangular window, but also to the nipple which is cast into the end of the injection pump's shaft and the corresponding nipple on the slotted drive of the oil pump. There appears to be an "art" to the remainder of the procedure (which involves a transparent plastic window with fine gradations embossed on it, put in place of the rectangular timing cover on the side of the injection pump, and starting the motor and watching the effect of speed/load on the movement of the timing mark - I have never attempted to do this). If you clean the base of your injection pump housing and remove the paint/grease oil at the place where the housing will bolt to your block, you will find some tiny (almost microscopic!) gradations (in degrees) which play some role in fine tuning the 2010. I am battling a timing problem right now with my 2010. Apparently, the previous owner did not install the injection pump correctly, and although it started and ran, it has never run GOOD. So when I went to check timing, I found that when the "D/C" mark is lined up in the little circular window on the bellhousing, the timing mark in the little rectangular window on the side of the injection pump was not even visible! I've concluded that the oil pump has been installed incorrectly, so I need to drop the oil pan and rotate the oil pump a tooth at a time until I can get the timing mark visible in the window. I have not done this yet, but when I do, I will also look for this little nipple on the end of the shaft and on the slotted end of the oil pump, because if this is ignored, you could install the pump 180 degrees off. Search the archives for valuable info that I am not capable of conveying. For example, view the most excellent and authoritative responses by jdmaris and others at Link and Link Good luck.
