D radiator installation
Skyhawk Greg
07-31-2005 07:15:34
Good Morning, Had a weeping type leak in-between the upper water pipe and the engine block on a 1935 D. Tried three bottles of Bars Stop Leak, and two packages of large GM Seal Caps. The leak greatly diminished, and even stopped on one portion, but never completely disappeared. Decided to replace the gasket. While at it, it seemed like a good idea to replace both the upper and lower water pipe gaskets, and the upper and lower elbow gaskets that hold the radiator up. Everything is now apart, cleaned up, and ready to be put back together. This is the first D radiator that I have installed, so I looked in the John Deere "Instructions and Parts List for John Deere Model D Tractor" for any pertinent information. It merely states, "If, for any reason, the elbows or upper water pipe are disturbed or moved, then care should be taken when the radiator is put in place that it sets squarely with the upper water pipe flange and the bottom elbow flange. This can be helped by tightening all of the cap screws a little at a time.". Now, this certainly seems simple enough, but I am going through in my mind what order I am going to do things in, and trying to anticipate any problems. I will want to do it right the first time since the radiator is somewhat heavey, definitely cumbersome, and there will be liquid gasket sealant on the new gaskets, and I don't want to make a real mess or ruin the gaskets. This is the order I have come up with: 1.) Attach the bottom of the upper water pipe to the block. Torque the bolts to full tightness since this will provide a flat reference point on the top of the upper water pipe for the radiator. 2.) Snugly attach the top of the elbow to the bottom of the radiator. 3.) Place the radiator onto the top of the upper water pipe and snug up the bolts while having someone hold the front of the radiator as flush as they can 4.) install the bolts to connect the bottom of the elbow to the block. Now progressively tighten all of the bolts.
It may be splitting hairs, but I would appreciate any input from someone who has done this before. With the weight of the radiator, and the vibration of the tractor in general, it seems like alignment should be pretty important to avoid unwanted stresses in the castings.
Thank you, Greg
Glen in TX
07-31-2005 08:49:22
 Re: D radiator installation in reply to Skyhawk Greg, 07-31-2005 07:15:34
Hi Greg, Take a look at your D radiator again. Most of the weight rests on the water pipe from the block. If you got other leaks it's a good time to replace the radiator gaskets as well as the water pipe gaskets on the block. I take the whole radiator in less the lower elbows here and after cleaning the core they put it together and pressure test for me. It has worked best for me to have the radiator put together with the lower elbows installed on the radiator assmembly and then lower it on the tractor with more help and strong arms or a hoist is best. The holes in your head should be somewhat slotted to give you some room. If not file out some of the cast flashing there. After setting in on there and getting all the bolts started and snugging down a little at a time pull the ones down on underside of tank and then the elbows last. Good luck.
