HELP - JOHN DEERE 336 SQUARE BALER
Ladena
07-30-2005 18:30:16
Posted wrong before. need to thread a John Deere 336 Square Baler in the morning. PLEASE HELP
Tx Jim
07-31-2005 03:36:08
 Re: HELP - JOHN DEERE 336 SQUARE BALER in reply to Ladena, 07-30-2005 18:30:16
Ladena,there should be a threading diagram on rear of baler.Tx Jim
LADENA
07-31-2005 06:49:29
 Re: HELP - JOHN DEERE 336 SQUARE BALER in reply to Tx Jim, 07-31-2005 03:36:08
No diagram. Anyone help?
j cook (iowa)
07-31-2005 07:37:22
 Re: HELP - JOHN DEERE 336 SQUARE BALER in reply to LADENA, 07-31-2005 06:49:29
Twine baler? Thread BALING twine? Nothing simpler!
From the left ball of twine in the twinebox, thread the end out of the twinebox through the provided opening. There will be a ceramic spool under the bale case. Pass the end of the twine through it, and thread the end of the twine through the end (bottom to top) of the left needle and then tie the end of the twine somewhere solid on the frame. Repeat with the right hand ball of twine and the righthand needle. When the needles cycle during the knotting process, they will carry the twine to the knotter, which will load itself, tie the knot, and cut the twine for the start of the next bale. the piece of twine which you tied the end of to the bale case or frame will trail on the ground there until you remove it.
bobby O
01-21-2006 18:16:27
 HELP - JOHN DEERE 336 SQUARE BALER in reply to j cook (iowa), 07-31-2005 07:37:22
I currently have a I N sq baler and I was was looking at a jd 336 i was wondering if u could tell me somthing about them thanks
wolfman
08-01-2005 20:11:14
 Re: HELP - JOHN DEERE 336 SQUARE BALER in reply to j cook (iowa), 07-31-2005 07:37:22
Well put , Cook. Make sure the twine was put through all the tensioners along the way-like the one where twine comes out of twine box. Also, when needles take the twine to knotters for that first time, you want to check to make sure none is wrapped around the bill hooks. If so -shut down & remove the wrap.
Tx Jim
07-31-2005 07:16:05
 check your email in reply to LADENA, 07-31-2005 06:49:29
nt
