power block
55 50
07-30-2005 17:18:32
I occasionally see an ad (like now in the photo ads) of a JD "A" with POWER BLOCK. Would someone please explain just what 'power block' means. Thanks
dexter
07-30-2005 20:34:49
 Re: power block in reply to 55 50, 07-30-2005 17:18:32
i have a b with a power block in it for sale and this one has a 5"bore instead of the orignal 4 11/16" so thats about it and it has alonger stroke.
55 50
07-30-2005 21:22:42
 Re: power block in reply to dexter, 07-30-2005 20:34:49
A longer stroke? Doesn't that mean you have a different crankshaft? How is that accomplished?
JPatton
07-31-2005 07:16:48
 Re: power block in reply to 55 50, 07-30-2005 21:22:42
Power Blocks were sold by Tractor Supply. They included the pistons. They got the "power" by increasing the bore size and the compression ratio. "B" power blocks were 5", "A" power blocks were 6" and "G" power blocks were 6 1/2 inch. The piston was taller and that is how they got the compression ratio increased. Not sure of the actual number but something like going from around 4.5:1 to about 6.5:1. And you are right. If you want to change the stroke, that is done with the crankshaft not the power block. Hope this helps.
J
55 50
07-31-2005 09:38:55
 Re: power block in reply to JPatton, 07-31-2005 07:16:48
Good explanation. thank you.
dexter
07-31-2005 19:44:47
 Re: power block in reply to 55 50, 07-31-2005 09:38:55
oops my bad guys i wasnt thinking when i wrote that.i dont know why i said that.
