4010 Hydraulic Problems
James-OK
07-30-2005 16:46:53
Having problems with Hydraulic pressure it will only hold about 1000 lbs and sometimes less. I took the pressure regulator off and hooked a pressure gauge directly to the pump and it went up to 2000 psi. Where do I go from here? Thanks.
Tx Jim
07-31-2005 03:45:38
 Re: 4010 Hydraulic Problems in reply to James-OK, 07-30-2005 16:46:53
James,I think that the priority valve for steering/brakes is not letting pressure through.What are you calling pressure regulating valve? Stroke control valve regulates pressure. Also stand-by pressure should be 2250 psi. TX Jim
James-OK
07-31-2005 07:49:39
 Re: 4010 Hydraulic Problems in reply to Tx Jim, 07-31-2005 03:45:38
what i am calling a pressure reg. is called a pressure control valve your main line comes from pump into control valve then brakes off to the power steering-rock shaft-selective control valve also when you turn the tractor off the 3pt. rock shaft leaks off in about 5 min. also what are you calling a priority valve Thanks james-ok
Tx Jim
07-31-2005 09:05:43
 Re: 4010 Hydraulic Problems in reply to James-OK, 07-31-2005 07:49:39
James,a rockshaft leaking down fast could be leaking thermal relief valve,bad piston o-ring or leaking control valves.Do your brakes and steering work properly? How long has it been since changing filter and cleaning screen? Tx Jim
james-ok
07-31-2005 10:44:37
 Re: 4010 Hydraulic Problems in reply to Tx Jim, 07-31-2005 09:05:43
the filter was changed last saterday the screen was cleaned back in february when i had to put a new top shaft in the transmission the steering worked fine untill the hydraulic problem started as for the brakes thay stop go but thay do make a rumbling sound when stoping i no it needs brakes but i sure do dread it thanks james-ok
