'44 B Manifold
Steve Martinez
07-30-2005 12:16:52
I have a '44 B which has a all fuel manifold that I need to remove. The studs are bad and will have to be replaced. How do I get the manifold off the studs(does'nt look like it has ever been removed) without breaking the manifold? I would like to leave enough of the studs so that I can heat the head and remove them.Any advice will be greatly appreciated. Thanks, Steve in S.C.
Skyhawk Greg
07-31-2005 06:57:24
 Re: '44 B Manifold in reply to Steve Martinez, 07-30-2005 12:16:52
Steve, I have a B that was built in 1944. When taking the manifold off, the nuts were completely rounded, so I took a power bandsaw and cut the studs at the interface of the bottom of the nut and the top of the manifold. The manifold came off pretty easily, and there was plenty of stud left to manipulate with a stud remover.
Jared K
07-30-2005 20:57:40
The best way that I have had luck with stubborn bolts as those is to take a hammer and tap on them. The heavier the hammer, the lighter the taps. I have had good luck with a 16 oz. claw hammer. It takes some time, but once it breaks them, they will turn wasily with a wrench, and some will even come out by hand. Try turning the bolt every once and a while, and if it doesnt turn easily, keep tappin.
1944bhandcrank
07-30-2005 17:51:24
I have a 1944 B handcrank. I am finishing up a 3 year frame off restoration on this tractor. I hammered a socket onto the nut then tried to back it out. More than likely you will break off all four of the nuts. You can then slide the manifold off the studs. Then you can use a small pipe wrench to work the studs back and forth until you can back them out. You shouldn't damage the manifold doing this.
Is your 44 B a handcrank? I am looking for a clear photo of the "U.S.A. PAT." decal that is on the main case directly to the top left behind the flywheel. This is the only decal I need to finish mine.
I have a 1944 B parts tractor if your in need of parts.
David Lile
Wichita Falls, Texas
Steve Martinez
07-31-2005 12:32:40
 Re: '44 B Manifold in reply to 1944bhandcrank, 07-30-2005 17:51:24
Thanks to all for the advice and info.I will plan to try to remove the manifold following ya'lls advice. Mr. Lile, my B is indeed a handcrank. I'm sorry to say that the decal you mentioned is not on my tractor. I just may contact you about parts. Thanks Steve
