820 diesel engine knock
Curtis Weddle
07-30-2005 08:30:56
I have a 3 cylinder 1972 year model 820 diesel. We have had it since it was new and it is a tribute to JD durability.
When the fuel filters were last changed AND the fuel system purged, it developed a knock under load that seems to becoming from near the front cylinder. This is not significant load, only moving the tractor will cause the knock. I have been reluctant to try anything else.
Any thoughts on the cause?
Thanks,
MSM
07-30-2005 11:48:51
 Re: 820 diesel engine knock in reply to Curtis Weddle, 07-30-2005 08:30:56
Could have gotten some dirt/water in an injector and damaged the tip,giving it a bad spray pattern. This condition will give you the knock you hear due to incomplete atomization of the fuel at the nozzle(fuel knock)
Curtis Weddle
07-30-2005 21:34:50
 Re: 820 diesel engine knock in reply to MSM, 07-30-2005 11:48:51
Sounds like a reasonable assessment of the situation. Guess it is time for a tear down and check. I"ll pull the injector pump and injectors, take them to Ft. Smith Diesel Service and get it checked out.
Suppose they can also check the front seals on the pump at the same time.
