A transmission
jake pickerign
07-29-2005 11:56:05
Hey again, My A has a 5th and 6th gear cover on the side, but I though the 6 speed wasnt til 1941 and I have a 1940. I am not too familiar with john deere's because I have mainly worked on internationals. If you could fill me in on if it is a 6 speed and how it works, there is a lever coming out of the cover. some info would help alot. Thanks
Ron Fr.
07-29-2005 12:19:00
 Re: A transmission in reply to jake pickerign, 07-29-2005 11:56:05
It is the lever way on the left side. the lever by the high low is for the PTO.
Jake Pickerign
07-29-2005 12:22:57
 Re: A transmission in reply to Ron Fr., 07-29-2005 12:19:00
hey thanks alot, you guys are such a help. Thanks to everyone who has givin me input
Ron Fr.
07-29-2005 12:16:46
Hi Jake, My 40 A has the same add on 5th & 6th as yours. to operate it you, put the main 1-4th shifter in neutral, move the high low shifter in to low pos. for 5th and high for 6th. then move the lever on the add on, to engage it. push the clutch lever ahead and away you go!! A note of caution idel the tractor down before you try it. I am not sure what the road speeds of the gears are, but you will move right along. Good Luck and Be Safe
jake Pickerign
07-29-2005 12:20:56
 Re: A transmission in reply to Ron Fr., 07-29-2005 12:16:46
The main shifter has 1-2-R and then the high/low lever, is that what you mean by 1-4 gear shifter? sorry for all the questions but I really am clueless
Dick Dillman
07-30-2005 02:25:15
 Re: A transmission in reply to jake Pickerign, 07-29-2005 12:20:56
Ron Two cautions---if this Behlen add on gearbox is on a hand cranker, beware of mashed fingers and skinned knuckles. Been there-done that, also do not try to shift your main transmission when this is engaged as it will definitely destroy your gearbox. Good Luck with your toy. DickD
Ron Fr.
07-29-2005 12:22:20
Sorry for the confusion ya that is the lever you leave in neutral.
Mike n Mo
07-29-2005 12:11:14
It sounds like your tractor has a Behlen road gear. It was (is) an aftermarket kit to add the 5/6 gears to the 4-speed tractors. Put the main gearshift lever in nuetral, engage the road gear using the hi/low as desired. Mike
old
07-29-2005 12:07:51
This is just a guess but you may have a late model 1940 and sometimes that means it has the improvements for the next year put on
jake pickerign
07-29-2005 12:11:29
 Re: A transmission in reply to old, 07-29-2005 12:07:51
then is the lever coming out of the box what I use to get it into 5th and 6th? Either that or there is another lever by the high/low lever with no markings would that be it? thanks for the input
old
07-29-2005 12:24:24
 Re: A transmission in reply to jake pickerign, 07-29-2005 12:11:29
Not sure been to many years since I have been on an A. If you have it running I'd play with the levers and see what they do.
Jake Pickerign
07-29-2005 12:26:31
 Re: A transmission in reply to old, 07-29-2005 12:24:24
Its not running yet I just wanted to know so when I do get it running I dont look like a calf trying to walk for the first time when I drive it.
old
07-29-2005 12:36:06
 Re: A transmission in reply to Jake Pickerign, 07-29-2005 12:26:31
Shoot thats half the fun of these old tractors, best way to learn is by the seat of your pants, LOL. Thats how I have learn to many things. Which include welding, driveing a big rig, operating heavy equipment from backhoes to dozers etc. and of course tractors.
Jake Pickerign
07-29-2005 13:06:31
 Re: A transmission in reply to old, 07-29-2005 12:36:06
lol thanks for all the knowledge guys your a big help
