4630 Hydraulic Fluid Change
pbutler
07-29-2005 07:38:12
I am changing the hydraulic fluid in my 4630 this weekend. This is the first time I have done it.
If I recall it has about 25 gallons. All I have is a 3 gallon drip pan and a 50 gallon drum. If I put the pan under the bottom I am going to have to plug it 8-10 times and I am sure will make one heck of a mess.
Would there be any danger to putting a hydraulic hose on the remote-putting that in the drum, and then pumping out 15 or 20 gallons that way before doing the rest from the bottom? Any harm to pump or anything?
Mike M
07-29-2005 07:44:47
 Re: 4630 Hydraulic Fluid Change in reply to pbutler, 07-29-2005 07:38:12
Make sure you clean the suction screen too. I would not drain it while running,you will likely ruin some expensive parts. I would take that 50 gallon drum and cut it in half so it will lay on it's side and use it for a drain pan. Or at least go get some empty 5 gallon buckets.
txgrn
07-30-2005 06:50:31
 Re: 4630 Hydraulic Fluid Change in reply to Mike M, 07-29-2005 07:44:47
Seemed like a super idea, but you are probably right.
Agree that changing fluids is such a mess.
Mark
