70 distributor
stupid pup
07-29-2005 03:45:30
will it work on my 1948 B? its a delco, where does number one wire go, left or right of coil wire? looking inside the cap it looks like it fires 180 deg. how does the timing adv, the point plate dont move. the mags. don`t seem to hold up very long for me, the tractor is always shedded.
stupid pup
07-29-2005 06:39:27
 Re: 70 distributor in reply to stupid pup, 07-29-2005 03:45:30
boys thank you for the fast come backs, I got to looking the dis. and saw the arrow that shows the way it turns,the thing that had me stalled was the points are facing to the right in the dis. and to the left in the mag. a fresh mag. works good for about 2 years then after that its sand the points and regap then the spark starts to drop, the B with the 3 point and the low gear is handy for brush hogging. I dont like changing tools, so I change tractors,thanks again
John T
07-29-2005 07:44:52
 Re: 70 distributor in reply to stupid pup, 07-29-2005 06:39:27
One problem with mags is that youre dealing with such a limited amount of energy any thats wasted in a resistive voltage drop and/or heat across the points lowers the energy stored in the coil and ultimately discharged across the plug gap where its needed. Once you begin to file points the low resistance silver coating is removed and they really should be replaced. The governor shaft which drives a mag or distributor turns in the same direction and RPM as the flywheel, which can help you figure out the timing and firing which occurs each time the points break open which is approximately at the pistons TDC's.
John T
John T
07-29-2005 05:52:51
Pup, the "original" wiring configuration was top cap terminal to left cylinder and bottom to right. As far as firing, the left cylinder fires at TDC and then 180 degrees later the right fires on its TDC. If she pops n bangs n backfires you may have the wires swapped. Generally speaking if alls well the Delco battery powered ignition should provide more spark energy than a Magneto.
John T
Mike M
07-29-2005 04:24:56
It will work,# 1 is in the top hole when mounted,You should be able to hold the drive end still and rotate the rotor back and forth some if your weights and advance is not stuck. Don't know why you are haveing trouble with mags.they hold up good ? What is not holding up ?
