J.D. 60 won't run
JLH33
07-28-2005 20:44:42
I have a '53 J.D. 60 that won't run. I have fuel and fire, but still won't run. It ran before I run it out of fuel, but after refueling nothing. It has new plugs, good fuel, clean carb, cap, rotor, condensor, & points. I have racked my brain and can't find a reason why it won't run. I got to be overlooking something simple. Any help would be appreciated.
Thanks.
Jason
old bones
07-29-2005 18:40:53
 Re: J.D. 60 won't run in reply to JLH33, 07-28-2005 20:44:42
if you haven't already done so, you might want to unscrew the knob on the top of the sediment bowl assembly (between the sediment top housing and the fuel tank) and hold the little plunger in for a bit, long enough for the fuel to fill the fuel line and carb. my 60 has oil pressure activated sediment bowl- no oil pressure, no fuel can flow. just a thought.
John T
07-29-2005 06:23:52
JLH, Since it worked before she ran out of gas Im obviously thinkin the fuel system maybe at the sediment bowl is air locked or else she may have sucked some crud in the sediment bowl assembly. I agree with Old's approach and would first remove the gas line into the carbs inlet and insure good flow there the size of the lines ID. If not, remove the sediment bowl and see if shes getting gas out of the tank and into the glass bowl area (lil holes at top). There could be a restriction in the lil tank outlet pipe or the sediment bowl inlet area. This dont have the auto shutt off sediment bowl assembly like the 20 series does it??? If so see if when you unscrew the lil top knurled nut and hold it down gas enters the sediment bowl (Have line removed from carb so gas can flow when you do that).
AFTER you get gas to flow into and out of the sediment bowl and out the gas line and into the carb (maybe shes air locked) do like Old said and open the carb bowls lower drain and insure gas runs out the bottom continuous. You gotta get gas into and out of the sediment bowl and to the carb and then fill the bowl for her to run right.
John T
old
07-28-2005 21:29:36
You sure you ahve fuel to the carb and to the plugs?? Have you pulled to drain plug from the bottom of the carb and have a good flow of gas??
