720D injector leaking fuel out asmall pipe
freddy
07-28-2005 18:54:27
Checking the torque on the injector lines and found the #2 injector small line leaking fuel out. That pipe seams to go into the intake area. Small pipe that falls out once it comes off injector. What is it saying by the injector bypassing fuel out that line? The other one is not leaking.
Gpower
07-28-2005 20:03:26
 Re: 720D injector leaking fuel out asmall pipe in reply to freddy, 07-28-2005 18:54:27
If you are getting more than a few drops out that line, then you have several possible problems. (1) Bad delivery valve in the injector. (2)Plugged holes in the injector tip. (3) plugged passageways in the body of injector. The fuel that is used to lubricate the parts goes right out the tip into the cylinder.
Those lines do go right back into the intake portion of the cylinder head. If you were to take off the intake manifold and shine a light into the head you would see the ends of the lines in there. More than a few drops per hour, and you have a problem. I would take the injectors out and have them tested, along with the injection pumps. I can give you several places that do that work, and I do this work also. Send an e-mail for more info.
Freddy
07-29-2005 09:49:40
 Re: 720D injector leaking fuel out asmall pipe in reply to Gpower, 07-28-2005 20:03:26
Sounds like a plan. I am working O/T now and will not get to it for a while. Thanks for the help. Tractor is in the garage and I'll just not use it till I fix it.
msb
07-28-2005 19:19:18
Try loosening the line and repositioning it deeper in the head.It is a return line .The reason for it is for the fuel that leaks past the pintle in the nozzle body to have somewhere to go and not lock the nozzle up.The bypass also serves to cool and lubricate the nozzle itself.
