Hard starting unstyled D
rex barlow
07-28-2005 18:41:21
I have a a 1930 unstyled D that is kind of hard to start. Hand cracking is tough but it will start after much effort. I am using a rebuilt splitdorf mag and have good fire. The timing is right on and the carb was gone through but the throttle shaft could use bushings. If choked, (while cranking backwards) I get a lot of gas that runs out of the aircleaner end of the carb (and throttle shaft)and drips onto the block It doesn"t seem to be drawing fuel into the cylinders. I have adjusted the valves and I have roughly .030 clearence but I suspect that maybe I have an intake valve that is not sealing and causing me trouble. Could this be the issue? Is the gas running out of the carb a dead giveaway? I do have the fuel cup petcock valves and if I prime both sides and hold my mouth just right it will start a crank before my back gives out. I think it should start better.
Aberdale Farm
07-29-2005 08:56:25
 Re: Hard starting unstyled D in reply to rex barlow, 07-28-2005 18:41:21
Rex, my D starts hard, too. It pull starts easy, though. I just tore it back down (for other reasons), and noticed that my new manifold gasket wasn't sealing to the head very well. (warped manifold flange). I suspect I'm not getting enough vacuum to the carb. When I put it back together, I'm going to make sure I get a better seal. Just something you might want to check as well.
Dale
John T
07-28-2005 19:41:15
Rex, D"s arent my thing but I will toss out a couple things. If you have her in a real quiet location and the air inlet piping removed and crank her up to TDC on compression and listen careful if you hear a lot of pressue leaking backwards out the carbs intake that can indicate a leaky intake valve as you questioned. Similar, if shes leaking out the stack its a leaky exhaust valve and if via the crankcase leaky rings.
At low RPM or cranking with the throttle plate closed down thats a time of high vacuum in which case leaky carb throttle shaft bushings can allow air to get sucked in which leans the fuel/air mixture.
Thats all I have to say about that other then my usual answer of TRY NEW PLUGS.
John T
