JD 345 Power Loss Under Load
Mike I.
07-28-2005 18:11:38
Hi All,
I have a JD 345 with 40 hours on it.
Last time I mowed the lawn all was fine. Yesterday, I pull her out of the garage and now find that she is bogging down big time under any sort of load, can not even make it up the hill in my back yard.
She starts right up and the engine sounds fine. The problem is that at anything more than 1/3 pedal and she is clearly running much slower than normal and will bog down even giving a puff of smoke. High grass will have same effect as will a hill. I did change the plugs and fuel filter just for good measure but it had no effect. Kind of like driving a car only using 3rd gear.
Any thoughts?
Thanks.
tractornutjd
07-29-2005 18:04:58
 Re: JD 345 Power Loss Under Load in reply to Mike I., 07-28-2005 18:11:38
Hi Mike. Try checking for spark at both coils. Also remove the valve cover and make sure that a puch rod didn"t fall off a rocker arm. Check to see if there is any water in your carburetor float bowl. I"m a JD L&G tech. good luck, tractornutjd
Mike I.
07-30-2005 15:57:58
 Re: JD 345 Power Loss Under Load in reply to tractornutjd, 07-29-2005 18:04:58
Thanks, that was it! I pulled off the valve cover and one of the rocker arms was indeed detached from the rod. Pushed the rod back in place and all is back to normal. Thanks again, saved me a trip to the dealer.
