JD 300 Backhoe
Gil
10-24-1999 17:25:52
Any ideas why a JD backhoe just decided suddenly that it would not move forward or reverse? Front bucket and backhoe both work, but tractor will not move. Thanks
Dan Heuberger
08-30-2003 17:40:24
 Re: JD 300 Backhoe in reply to Gil, 10-24-1999 17:25:52
change your filter
Jonathan
10-25-1999 06:38:03
Is there any indication that there is shaft movement(turning) in the transmission case ??? Try shifting the gear selector with reverser (if equipped) in forward...any grinding ??? Does the park position hold the machine ???(push with the backhoe to test)...If the park does not hold and there is "audible" indications that the internal components are turning, the rivets may have sheared off of the ring gear in the differential...just some areas to check ....
