I recently finished restoring a 1927 D. I tore it down far enough to install used pistons (one of the originals had a broken skirt), new rings, new rod bearings, a valve job, new valve springs, new pulley bearings, a used clutch drive disk (mine had several cracks) and new clutch disks. I've run it for about 2-3 hours since the work was done. Obviously I didn't do a very good job, because I seem to have extra vibration in the engine, and I'm leaking coolant into the oil. On the vibration, I've checked to make sure that the flywheel is on right. It is splined, and there is one tall spline that fits over a pin on the crank, so I think it's on correctly. I also rechecked the clutch drive disk. It is keyed to the flywheel, so can only go on one way. So I'm not sure what to check next. On the coolant in the oil, it's leaking pretty slowly. I don't think coolant is getting into the cylinders. The shop that did the valve job checked the head for cracks and it appeared OK. So that leaves the possibility of a cracked block that I didn't see while I was honing, or a leaking head gasket or lead washers around the head studs. Any other possibilities that I may have overlooked? I'm letting the engine drain overnight, then I'm going to fill the radiator with water and see if I can locate the leak by looking behind the valve cover. After all this work it's really got me bummed. I'm open to any suggestions right now. Dale
