70D POWER STEERING
R POWELL
07-27-2005 18:03:20
NEED HELP HAVE A 1955 JD 70D STANDARD . THE POWER STEERING ONLY WORKS WHEN YOU FIRST START TO TURN THEN YOU LOOSE ALL ASSIST . DONT HAVE A PRESSURE GUAGE THAT WILL READ HIGH ENOUGH FOR A PS PRESURE CK ANY IDEAS ON WHAT COULD CAUSE THIS THANKS RICH.
buckeye al
07-28-2005 13:49:26
 Re: 70D POWER STEERING in reply to R POWELL, 07-27-2005 18:03:20
I read this message a bit differently the second time through.
You say; THE POWER STEERING ONLY WORKS WHEN YOU FIRST START TO TURN THEN YOU LOOSE ALL ASSIST.
That tells me it doesn't matter if the tractor is hot or cold, the power assist goes away in either case just after you start to turn the wheels. Like there's a burst of assistance but then it's gone.
Sounds to me like worm shaft bearing adjustments, pressure and valve adjustments need to be checked carefully. They are sensitive! I myself have never been into the cylinder and vane below. Others would know better if such a trouble could be caused by wear in the vane's seals.
If I'm reading your message incorrectly I apologize.
Later.
Blksmok
07-28-2005 08:16:15
Rich...pretty hard to diagnose until you know that the pump is putting out the specified pressure. If the pump is ok, then suspect that the steering vane packings (R1697R) are leaking or maybe you have a broken steering vane pin (F1700R). Neither one of these is a quick fix though. Find/borrow/buy a gauge to check pressure first.
buickanddeere
07-28-2005 06:00:20
She's worn out. When the fluid warms and thins the system pressure drops. You might get by for a while by cranking up the flow rate adjustment.
F-I-T
07-28-2005 06:30:50
 Re: 70D POWER STEERING in reply to buickanddeere, 07-28-2005 06:00:20
What type of fluid are you using? If it is not the original JD "Power Steering Fluid for Tractors 1960 and earlier" it might be too thin to begin with.
If it an early 70 with the relief valve on the side of the pump, it could have a problem, but and B&D says, she's likely worn so far that the clearances are letting hot thin oil pass by. Not a bad job for reseal and overhaul, though a few parts in there, if worn to excess, can be expensive.
Frank
