1940 model A....can you help me?
jake pickerign
07-27-2005 11:21:31
I have a 1940 john deere A tractor with a serial number of 496533. this site says that is has the 309 ci engine turning 18 horse but some other sites tell me that I have the 321 ci engine with 34 horse. I am not sure which to believe. I am going to restore this tractor. I would just like to know more about it. Thanks
JR in TX
07-28-2005 07:17:02
 Re: 1940 model A....can you help me? in reply to jake pickerign, 07-27-2005 11:21:31
Yes, you have a 321 cu in engine. The longer stroke started at 488,000. The six speed transmission started at 499,000. The 1940 A's have a unique combination of 321 ci and a 4 speed transmission. I have a Model A serial no. 488177 with this combination.
WTW (Correction)
07-27-2005 14:26:57
Jake, The fact is your tractor is a 1940 model as you stated. The 1939 model had the 309 cube engine same as the unstyled tractors. The 1940 was a 321 cube engine. The 321 engine was introduced in 1940 starting with serial number 488000, block casting number A2324R. This block was used through 1946 and in 1947 was changed again to a different design. Both 39 and 40 model tractors shared the common 4 speed transmission. The six speed transmission was introduced in 1941. Parts book will show this information and serial number breaks. A 1940 model is unique as it has the old 4 speed transmission and the first year 321 engine. Hope this helps, DW
Dick Dillman
07-27-2005 13:38:56
Hello Jake; Your tractor (1940 A) has a 309 cu. in. engine and is Nebraska rated at:18.72 drawbar, and 24.71 PTO and belt. It was built late in 1940, but the 321.2 cu. in. engines came out in 1941, according to Larry Dunning's Data Book. I have a 1940 A that sold new out of an old hardware in my hometown.
I am doing a 1939 B and then it is next. If I can be of any more help,let me know. Good luck with your project. DickD
CMB
07-27-2005 17:25:01
 Re: 1940 model A....can you help me? in reply to Dick Dillman, 07-27-2005 13:38:56
As usual, Larry Dunning is wrong!!!!! !!!!! ! WTW is correct, ALL "A"s aftyer 488000 had the 6 3/4" stroke engine!
jake pickerign
07-28-2005 12:34:00
 Re: 1940 model A....can you help me? in reply to CMB, 07-27-2005 17:25:01
Hey guys thanks, this really helps alot. I am looking for a puller and when I found that I had the 309 ci engine I was just going to paint it and sell it but now I will stick with it. Thanks alot guys!!
