830 grill
Herb Scholten
07-27-2005 07:03:36
I am restoring my 830. This might sound dumb, but I cannot get the grill off the front end. The grill is bolted on the top on the backside of the radiator with two bolts. I am looking for the bolts on the bottom, but I can't find any that holds down the bottom of the grill. Hope someone out there that can help me with this. Thank you in advance. Herb
JDBert
07-27-2005 09:47:37
 Re: 830 grill in reply to Herb Scholten, 07-27-2005 07:03:36
Herb, theres 2 3/8x5"(?) bolts at the bottom of the radiator (engine side) that go all the way through to the front and hold the grill (bottom rounded nose part) NOT FUN TO GET!! I had to torch them on my 820. I think its also possible to take the grill off at the bottom of the up and down part (yellow) and separate it from that bottom nose.
Jack Kohl
07-28-2005 15:27:04
 Re: 830 grill in reply to JDBert, 07-27-2005 09:47:37
Herb-I just did the same thing with my 820. Those two bolts in the bottom release the entire nose top and bottom tin work plus the screen. Once off the tractor, there are four long bolts holding the top and bottom together with the screen. These are easy to take apart, but HARD to get back together. I finally tied all three pieces together to take up the slack so I could get the four long bolts back in place. Sure makes the old girl look good when you get that new grill in and back on.
