70D fuel filter project
Jake70D
07-27-2005 05:12:49
New to us tractor, and we are doing services to it. Going to hit the 1st stage fuel filter next which I have from deere. I have the sediment bowl off and cleaning and so the fuel is cut off. I note in the manuals that it says to not do the 2nd stage unless overhaul or very messy 1st stage. Ok, no problem.
But I see ahead that when I take the retaining bolts off the bracket holding the filter cups, wont both filters likely will fall out with it? I guess my post is can anyone kind of talk me through doing this correctly. I assume some diesel will spill out, will the filters fall out too? I will leave the 2nd stage and put it back in and re/re the first one. I only have o-rings and gaskets for the 1st stage so I hope that is not an issue for the 2nd stage. Who knows when it was done last.
Just want to do this well, cant have a cluster F- mess dealing with diesel fuel in an unprotected environment when its opened up. I want to be successful here.
Thanks
Mike M
07-27-2005 06:59:14
 Re: 70D fuel filter project in reply to Jake70D, 07-27-2005 05:12:49
I have always did both at the same time and never regretted it as I found junk and water in both. If they wanted you to only do one at a time they should of used seperate retainers. Some I have even pulled the whole assy. off the tractor then take it to the workbench and operate on it.
Dirtjockey
07-27-2005 06:33:55
I have a 720D so I am not sure what has changed from the 70D. What I found out was the bottom of both of my bowls were just about rusted out from water standing in them. NO DRAINS. Also they both had growth / slime in them. In the end I could not save one bowl and the top casting due to rust and went to the junk yard and found another one. Which I tell you was not easy considering they are all mostly like that. My suggestion is this - If new tractors with ultra high pressure close tolerance fuel systems require both filter (sometimes only one filter made together) to be changed then I would change both on a low pressure system like this. I had no problem bleeding mine and it started and ran fine. With any fuel systems remember just keep everything as clean as possible. I removed the bracket and bowls, washed everything carefully, reassembled and reinstlled in tractor. make sure to plug the lines when removing and reinstalling. This will prevent the accidental ingestion of dirt in to a line.
F-I-T
07-27-2005 06:24:26
Jake:
The filters will stay "stuck" via tension on the o-rings and stub pick-up ports, so you will be able to drop the cans and the filters stay put.
However, if it were me, I would go ahead and replace that secondary filter. Why wonder for $6.00? I change them anytime I have an interest in changing the primary.
Frank
TBSCOTT
07-27-2005 06:22:43
Do them both if you have them down. If you don't know the history on the tractor they might need changing but usually not. If you change them they will probably never need changed again. How did the sediment bowl look?
Jake70D
07-27-2005 06:28:16
 Re: 70D fuel filter project in reply to TBSCOTT, 07-27-2005 06:22:43
Not too offensive actualy. It is discolored, I think maybe even permanently. I have is it soaking now, and may need to go to brake clener or carb cleaner on it. The diesel is clean that is in the system (to me) and I have put conditioner in too.
Do you know why it tells not to do both at once all of the time? Is it a bleeding issue or an air issue? Or just a cost saving measure I wonder?
Gpower
07-27-2005 15:14:10
 Re: 70D fuel filter project in reply to Jake70D, 07-27-2005 06:28:16
The easiest way to clean those diesel sediment bowls is with a SOS pad, get the ones with soap in them and they work even better. It dont scratch the glass either. Clean it right up. BTW don't drop it!
GP
F-I-T
07-27-2005 06:30:57
Jake:
I think it's two things:
1) If you don't disturb it there is no way for a spec of dirt to enter the injector pump side and
2) Why waste a filter if it is not needed.
Frank
