JD 336 baler help (continued)
MN Bob
07-26-2005 19:39:04
Thanks to those that responded. I spent Tues and Wendsday at the farm. Took the wiper arms off, cleaned everything, sharpend the knifes and rolled the flysheel till my shoulders hurt. Everything worked like it should till the twine entered the knotter. broke between the knotter and needle. Tested the pull again. 25 to 35 lbs. Problem, Twine hanging up inside the twine bale. That goes back tomorrow and I will try polypropelene. Moral, try the simple stuff first. Oh yes, I did some rock picking and summer fallow along with the baler work.
jd68
07-30-2005 07:01:35
 Re: JD 336 baler help (continued) in reply to MN Bob, 07-26-2005 19:39:04
simple put.....If you can't bale and knot properly with sisal you'll never knot with poly.
Loren
07-30-2005 08:41:07
 Re: JD 336 baler help (continued) in reply to jd68, 07-30-2005 07:01:35
I"m backwards again. 3 times I"ve tried sisal and haven"t made it work. Baled 18,000 bales in the last 4 years on twine from an old Case baler.
