Another M Question
Front Axle Pivot Pin
JerryU
10-24-1999 13:59:23
Again, my father in laws tractor. Got the clutch going thanks to your help, now he decided to pull the front end. The casting that the pin runs through is wallowed out. Couple of questions:
1. How do you get it apart. He pulled the two wire clips off the ends of the pin, but nothing budges. Looks like there might be some more clips down further? Something to do with the slots on the casting?
2. Did the casting (not the axle part) have bushings in it? Looks like the pin is not worn but the casting holes are egg shaped. We plan on boring it and putting in bushings-that is if we can get the pin out.
3. Is the pin mounted in some kind of rubber bushing in the axle or is this just gunked grease?
I have discouraged him from any further brute force methods until I get some answers.
I'm kinda new to the John Deere stuff (Have a JD lawn tractor, but a Ford 9N)
Thanks
JerryU
