JD 2520 Hydraulics
Pete2520
07-26-2005 17:15:49
I"d like to hook my loader on my 2520 to a separate valve. Where can I tap in for hydraulic pressure for the valve? Where can tap the return into? I don"t want to use the the tractor valves and couplers.
MSM
07-27-2005 16:13:17
 Re: JD 2520 Hydraulics in reply to Pete2520, 07-26-2005 17:15:49
Go to your Deere dealer and buy a power beyond kit. It mounts under one of the remotes,doesn't affect the remote operation,and makes plumbing in hoses to the loader valve simple without a plumbing rig job under the cowl.Costs about $110. and comes with everything you need.
Devon Hubbard
07-27-2005 04:46:31
The priority valve on a 2520 is located under the cowling - in front of the steering wheel & it is on the right hand side of the tractor. Here is what I did on mine: I replaced the large steel line that goes from the priority valve to the rear hydraulics with a fabricated hose. I put a tee fitting in between the fabricated hose & the priority valve. Send me your e-mail address & I will send you a picture.
Paul in WI
07-26-2005 19:35:38
I just put a joystick on my 2510.
Run the return to the Hydraulic Filter Cover. You will have to buy a ported filter cover available at your JD dealer. On the 2510 there is an elbow just to the left of the left brake pedal that comes out of the steering, etc. riser and runs to the back of the tractor. Replace that elbow with a "T" for a source of oil. Now, I cannot recall if the 2520 has that same elbow but in either case the source of oil is coming from the priority valve.....you need to tap into the secondary circuit coming from the priority valve (not the primary circuit supplying the Power Steering and the Brakes).
The other alternative and likely the best alternative is to get a "Power Beyond" kit for your tractor. It bolts on between the rockshaft housing and the SCV valve. Good Luck. Paul
