3300 Combine Brakes
Tim in West. P
07-26-2005 12:51:42
We are looking at a 3300. The owner tells us that the brakes may need work. One side sticks/hangs up.
Anybody ever work on the 3300"s brakes?
Are parts available?
How tough of a job are they?
Are the expensive?
tom grady
08-12-2005 20:05:39
 Re: 3300 combine the engine heats up and the shaf in reply to Tim in West. PA, 07-26-2005 12:51:42
Is there any way to replace shaft coming out of the engine without taking out the motor. or where could a person get some parts. the motor also heats up combining oats with all the dust. Maybe it is worn out and time to retire it.
Glen in TX
07-26-2005 14:25:08
 Re: 3300 Combine Brakes in reply to Tim in West. PA, 07-26-2005 12:51:42
Take a look at parts catalog at jdparts.deere.com and search for 3300 catalog and check some numbers to find out. If like a 6600 it probably has hydraulic brakes with a master cylinder under cab and then a drum with cylinder and shoes by each wheel. First thing to do is check for leaks. May just be a leaky line to one side ??
Mike Aylward
07-26-2005 15:23:31
 Re: 3300 Combine Brakes in reply to Glen in TX, 07-26-2005 14:25:08
Tim, I'm pretty sure the 3300's have brakes activated by cables. The 4400's take the same type of brake (disc type) but are master/slave hydraulic brakes. The larger 6600/7700 combines have drum brakes that are hydraulically operated. Odds are a brake cable is hanging up. The disc brakes in the 3300/4400 combines are not any better than they need to be so you will want to check them out pretty well. Hope this helps. Mike
RalphinWI
07-27-2005 20:25:59
 Re: 3300 Combine Brakes in reply to Mike Aylward, 07-26-2005 15:23:31
Mike Crawled under one this afternoon after combining some oats on WI sidehills. They are cable activated, at least for a combine with a serial 5xxx.
bryan s
07-26-2005 20:05:26
the brakes stick on a 3300 because the brake lined disc are so worn the cam action turns so far it 'sticks" the the 2 balls in between the center 2 "steel" disc-a new set of brake disc and clean it all up it will work fine.
