870 PTO Clutch will not release
Dan_870
07-26-2005 08:02:08
I have seen alto about PTO clutch problems and I am wondering what the normal fix is for this type problem I have adjusted the clutch pedal linckage and that has made now diffrence. Any ideas out there on this. Its a John Deer 870 disael
Glenn Forrest
04-17-2006 09:54:17
 Re: 870 PTO Clutch will not release in reply to Dan_870, 07-26-2005 08:02:08
My 870 has a similar problem. With the tractor off, I can enage the belly PTO, but the safety switch will not let the tractor start while the PTO is engaged. With the tractor running, the PTO grinds as you try to enage it. The rear PTO seems fine. The main clutch works fine.
I removed the shield where the linkage enters the transmission. The lever for the PTO clutch seems jammed. Any ideas without going into the tranny?
Glenn
