4230 head bolts
dave armstrong
07-26-2005 06:03:05
Can anyone email me the tighting pattern for the head bolts on a 4230
G/MAN - update...
07-26-2005 10:23:31
 Re: 4230 head bolts in reply to dave armstrong, 07-26-2005 06:03:05
According to Deere, do NOT use the torque-turn method when installing the new cylinder head cap screws on a 404. Use the recommended torque specs in the service manual. Also, there are two different head gaskets available - one thicker and one thinner. Which one is used is determining by measuring how far the piston protrudes from the cylinder liner at TDC. If any piston exceeds .009" protrusion from the liner, use gasket R53438. If none protrude higher than .009", use gasket R48291. Using the wrong gasket can lead to broken liner flanges, so it's very important to install the correct one. Your Deere dealer should be able to provide you with all the correct info you need. The DTAC solutions are #21476 and #23054.
G/MAN
07-26-2005 10:14:16
As was stated, use new caps screws and the new torque sequence, but check to make sure you need to use the torque-turn method. The new pattern is used across the board on the 466 and newer engines, but I recently learned where it ISN'T always used on the 404 engine, which is what your 4230 has. I've done several 404s and have always used the torque-turn method and haven't had a problem, but I don't think it's recommended for the 404, particularly if it's naturally-aspirated. I'll do some more checking and get back to you.
donmyeil
07-26-2005 07:14:36
Deere has a new torque turn method thats completely different. Use it with new bolts.
txgrn
07-26-2005 06:55:42
Any engine uses the cris-cross center out. Start in the very center (closest bolt to center) and make the smallest x you can make. Then move out to the next row of bolts keeping alternating back and forth, up and down in the x pattern till you get to the end.
I usually snug them up, snug again, then put the final torque on them always following the criss cross x pattern.
Never saw a head that was torqued otherwise.
Mark
G/MAN
07-26-2005 10:11:52
 Re: 4230 head bolts in reply to txgrn, 07-26-2005 06:55:42
Then you haven't worked on many Deeres. The "new" torque pattern - which has been around for a long time now - for 400-series Deeres starts at the rear of the head, goes around the outside bolts, and then works from the very center screws to the OUTER center screws and then back to the inner center screws.
txgrn
07-27-2005 07:00:00
 Re: 4230 head bolts in reply to G/MAN, 07-26-2005 10:11:52
Doesn't make sense.
Mark
G/MAN
07-27-2005 07:20:15
 Re: 4230 head bolts in reply to txgrn, 07-27-2005 07:00:00
It makes sense to the Deere engineers who came up with it. They fought head-gasket sealing issues for a long time on the high-horsepower 400-series engines before coming up with that sequence. And it works.
Mike M
07-27-2005 11:55:04
 Re: 4230 head bolts in reply to G/MAN, 07-27-2005 07:20:15
Do they still want you to retorque them after warmed up ?
G/MAN
07-28-2005 07:32:10
 Re: 4230 head bolts in reply to Mike M, 07-27-2005 11:55:04
I THINK they may still say to on the 404 if you you're not using the torque-turn tightening, but I can't say for sure. On the torque-turn engines, you don't. There's an ungodly amount of squeeze there, and with the torque-turn method, you're stretching the cap screw to its yield point. They can't clamp any tighter than that.
txgrn
07-27-2005 08:57:24
I hear you. Maybe the fact that it's a wet sleeve diesel has something to do with the sequence. Just seems like they are squeezing the outside and leaving no place for the inside to go but maybe that was their point.
Mark
G/MAN
07-28-2005 07:33:53
 Re: 4230 head bolts in reply to txgrn, 07-27-2005 08:57:24
I think that's exactly the idea. Starting in the middle and working out pushes the gasket out progressively further. The main trouble-spot has always been the RH rear corner at the oil passage to the head. So by clamping the gasket solid around the perimeter first, it's already pushed out as far as you go. Actually, you DO technically start in the middle at cap-screw #17. You torque it partway first to keep the head from "rocking" and then start the perimiter torquing.
