70 diesel standard industrial
Jay R
07-25-2005 18:48:54
just picked up a john deere 70 diesel standard with an adjustable front and 3pt hitch. I found some yellow paint on the main case just below the fly wheel cover, behind the dash( need to remove hood to see it) and I also found yellow paint near the rock shaft and hydraulic outlets. my question is- could this tractor have been built with industrial yellow paint out of the factory or is it undercoat primer? any other clues i could look for?
thanks,
Jay R.
buckeye al
07-27-2005 14:19:57
 Re: 70 diesel standard industrial in reply to Jay R, 07-25-2005 18:48:54
My 70 D has yellow all over the place. Under the flywheel cover there is no green, only yellow. I'm owner #2 & owner #1 bought it as a row crop green AG type tractor with a narrow front end. Not saying NO to your question, just letting you know yeller paint ain't rare in the green areas of these tractors. Do as others have said to make sure though.
JAY R
07-26-2005 14:40:22
it has 18.4 -30 size rears on it, also has an upright air cleaner stack whick i hear is rare for a 70 diesel standard but i am not sure?????
thanks
JAY R
buickanddeere
07-27-2005 08:10:12
 Re: 70 diesel standard industrial in reply to JAY R, 07-26-2005 14:40:22
A 70 retrofitted with the dealer or field installed air intake stack is rare around here. I never seen one until bringing a 70LP back from Texas.
Maark
07-26-2005 12:50:10
I don't think they used much yellow primer on a tractor in the mid 50's, inside the tranny case for a sealer maybe.You might scratch the paint down to bare metal ans see if there is a hint of green below the yellow. But as others said check under the sheetmetal, maybe under the front by the radiator and steering pedestal
Island A
07-26-2005 06:53:50
Probably primer, but it is possible it could have been painted yellow. What kind of tires are on it? I agree with the other guys, check the sheet metal thoroughly and have your SN checked.
Check this site out>Link
Nice>Link photos of a 70 industrial.
Dave
Blksmok
07-26-2005 05:18:48
Jay...look for signs of yellow paint on the backside of the sheet metal parts (air cleaner,hood, nose cone). They were not primed with yelllow primer as were some of the castings. I'm not sure if any 70's were sold as industrials. What is the serial number?
buickanddeere
07-25-2005 22:17:40
Run the serial number with the Two Cylinder Club. Odds are it's factory primer you are seeing.
