1952 JD G Front Hubs
Tim Martin
07-25-2005 18:47:29
I have a 1952 G tricycle front end without roll-o-matic with two different hubs; one is casting number A1553R, one with casting number A3479R. Which hub is correct?
Matt@miller
07-25-2005 21:13:51
 Re: 1952 JD G Front Hubs in reply to Tim Martin, 07-25-2005 18:47:29
A3479R Hub is the correct Hub for the Roll-a-matic. The G used the A1553R Non revisable rim Hub on the unstyled G and early GM Tractors, and it was also used on unstyled and early straight frame A�s
Tim Martin
07-26-2005 17:26:07
 Re: 1952 JD G Front Hubs in reply to Matt@miller, 07-25-2005 21:13:51
Thanks very much for sharing this information. Given both hubs do not match the vintage of this tractor, what is the correct hub? Would I be better off just keeping these two mismatched hubs and replacing the bearings and seals?
