Help, Gas in Oil
O'Neil
07-25-2005 17:21:39
I just bought a 1960 model 730 gas, when i got it it had about a gallon of gas in it, so I Put 5 Gallons more in it. That was a couple of weeks ago when I went to start her today, she was out of gas, and guess where it all was. When I took the dipstick out to check the oil the gas started gushing out like a geyser. What is my problem ????? ? Please tell Me Thanks
Raysflhs
07-26-2005 10:25:51
 Re: Help, Gas in Oil in reply to O'Neil, 07-25-2005 17:21:39
Bought a "58 720 recently with exact same problem plus wouldn"t idle. The carb didn"t look like it had been touched since new so off it went to get rebuilt (Roberts Carburetor, Spencer, IA). The seller apprised me of problem and recommended this route. Even with new/rebuilt carb, turn off gas when not running.
John T
07-26-2005 06:28:30
O"Neil, Those rubber diaphram rebuild kits are available from Mother Deere but I also additionally replace the o ring/washer on the top of the vertical shut off plunger when I rebuild those automatic gas shut off assemblies. What happens is the rubber diaphrams in those spring a leak which lets gas flow into the lil oil line that goes from the engine up to the oil pressure gauge and it runs down into the crankcase. If working right they are supposed to shut the gas off when theres no oil pressure (tractors off) but oil pressure pushing against the rubber diaphram opens the lil vertical shut off plunger allowing gas to the carb. If you remove the lil oil line there at the Tee on the assembly and gas not oil is present, you found the problem.
John T
Mike M
07-25-2005 18:26:32
That should have an automatic shut off bowl. Sounds like it is in need of new diaphrams.
Mike M
07-25-2005 18:26:22
old
07-25-2005 18:24:15
The best way to stop that is turn off your gas valve when you park it. Carb neelde seats are good for that and its a common problem.
Nicolas
07-25-2005 18:13:45
sounds like a bad needle and seat in the carb, or some trash getting in there and keeping the needle from sealing. Had the same problem on a '49 A, put an inline filter in the fuel line and cleared it right up. Hope this helps. Nick
