Clutch fork bearing removal on 1952 JD G
WaltND
07-25-2005 16:53:50
I need to remove the clutch fork bearing, fork shaft and pulley brake assembly on a 1952 JD "G". The bearing and/or fork shaft needs to be re-worked as they are very loose. My question is: should the clutch be engaged or disengaged when I pull the fork assembly out?
Thank you in advance for your help and suggestions.
Walt
Mike M
07-25-2005 18:30:23
 Re: Clutch fork bearing removal on 1952 JD G in reply to WaltND, 07-25-2005 16:53:50
Disengaged would be better. May as well go ahead and pull off the pulley and repack the bearing too.
